Ryhmätilaus: Scratch Removal & Polishing SuperKit
Binh
Olisiko kellä kiinnostusta osallistumaan ryhmätilaukseen?
Hyviä arvosteluita saanut jenkiläinen Scratch Removal & Polishing SuperKit
The Most Effective, Most Complete, Lowest Priced, and Best Guaranteed product of its kind!
Our selection of the highest quality of micron graded abrasives is the key to the effectiveness of these kits. You will receive one sheet each of 30, 15, 9, 3, 2, & 1 micron scratch removal patches. Each sheet is comprised of fifteen squares measuring approximately 0.8125 inch or 2.06 centimeters each. Each sheet is labeled with a grid pattern on the backside to reduce waste and is labeled with its micron rating to simplify the task of scratch removal and polishing.
The Pioneer Shino Rouge Cloth contains much more rouge than other rouge cloths. The heavy rouge concentration makes it more efficient at removing hairline scratches and polishing than other rouge cloths!
The Super Grabby Non-Slip Work Mat which keeps the watch firmly in position allowing you to precisely hone the surface. The non-slip work mat leaves no residue and protects the watches backside from scratches while it is being polished.
The Cape Cod Polishing Cloth is used to remove any surface contaminants and as a final step in the polishing process to provide the metal with a superb display case shine.
The Pin Removal Tool will greatly simplify removing links to resize approximately 99% of metal watch bracelets made. To remove the pins without a tool like this is near impossible. Comes with 2 extra tips stowed in a hidden compartment in the false bottom.
The Microfiber Cloth is a soft, non-abrasive cloth with special micron split array fibers and works wonders to wipe away smudges on polished metals and other reflective surfaces. You should never use your shirt or a paper towel to wipe polished surfaces. The color of the microfiber cloth is may be different than pictured.
The Superkit will provide you with everything required to remove any scuff or scratch caused by normal wear and tear and restore BOTH brushed AND mirror finishes; even moderately severe accidental damage can be greatly diminished or even removed.
If after 30 days you are not completely satisfied with it for any reason simply return it. When we receive the kit we will refund 100% of the purchase price minus initial s&h if applicable.
Hinta on 38,99 USD mutta varmaan saadaan jonkin näköistä alennusta.
Täältä pääsette katsomaan ennen ja jälkeen kuvia: http://www.watchbandrenew.com/before-and-after-photos.html
Vs: Ryhmätilaus: Scratch Removal & Polishing SuperKit
Voisi tuota kokeilla, varsinkin jos saadaan joku hyvä kimppa-alennus.
Minut voi lisätä myös joukkoon mukaan. :)
Olenko vähän myöhässä..? Jos vielä ehtii niin olen mukana!
Valitettavasi ryhmätilaus ei toteudu korkeasta ALV ja tullimaksuista. Tulee halvemmaksi tilata itse suoraan myyjäyritykseltä.
Mika M.
