Panerai PAM 00389, harvemmin saatavilla. Upea kunto ja erinomainen kello jossa keraaminen bezel. Kellon runko on titaania joka on kevyt ja lämmin ranteessa.
Mielestäni yksi upeimmista Panerain malleista. Koostaan huolimatta, istuu jopa 17,5 cm ranteessa hyvin. Titaani on kevyt materiaali, joten kello ei keiku ranteessa.
Kello on huollettu Panerailla -19 joten huolettomia vuosia edessä. Panerain huollot taitavat alkaa siitä 750€ luokassa joten sillä rahalla saa rannekeita tai jotain ihan muuta.
Kellosta kaikki paperit ja laatikot tallella.
vaihdossa#
- Omega Seamaster
- Panerai
Erikseen voidaan katsoa rannekkeita jos niille tarve. Löytyy nahkaa, kumirannekkeita, Panerai OEM sekä tarvike.
Kellon mukana tulee alkuperäinen Panerai kumirannekke.
LUMINOR SUBMERSIBLE 1950 AMAGNETIC 3 DAYS AUTOMATIC TITANIO - 47MM
Luminor Submersible 1950 Amagnetic 3 Days Automatic Titanio - 47mm
Titanium, 72.0, 30 bar (~300 metres)
International Limited Warranty expired
The movement of this special Submersible is the P.9000, which offers a convenient system for regulating the hour hand that can be moved backwards and forwards in jumps of exactly one hour, correspondingly changing also the date display.
Entirely designed and created at the Officine Panerai Manufacture in Neuchâtel, the P.9000 is 13¾ lignes in diameter and has 28 jewels, a variable inertia balance and an Incabloc® anti-shock device.
Indeed, the typical Luminor Submersible case by Officine Panerai houses beneath the dial a special soft iron case forming a Faraday cage that protects and isolates the movement from the flow of magnetic fields. This model guarantees a resistance to magnetic fields equal to 40,000 A/m (Ampère/metre), a limit more than eight times greater than the value specified by the international standards of the Normes de lndustrie Horlogère Suisse (NIHS 90-10). In extreme conditions, and in everyday life, watches are often exposed to magnetic fields generated by electric charges and currents. Such magnetic fields can noticeably alter the rate of the watch, a possibility that is virtually non-existent in the new Luminor Submersible 1950 Amagnetic 3 Days Automatic Titanio.
Applied to the rotating titanium bezel, inspired by that of the models made by Panerai for the Egyptian Navy in the 1950s, is a disc of matt black ceramic, on which the linear and dot-shaped titanium markers are fixed. The bezel rotates only in an anti-clockwise direction, to prevent accidental shocks interfering with the measurement of the time of the dive.
The movement is characterized by the precision of its construction and the two barrels which are constantly charged by the oscillating weight in both directions, thus ensuring a 3-day power reserve
H 6990€
vaihdossa#
- Omega Seamaster
- Panerai
H 6990€
