Getat + Kellofoorumi = Limited Edition
Vs: Getat + Kellofoorumi = Limited Edition
^ Juuri niin ja kiitos kun tarkensit asian puolestani!
Kyllä äänestys pitäisi näkyä kaikille. Vilkaisitko ketjun eka sivua?
Binh sanoi:
Binh sanoi:
Näistä ollaan päätetty:
KOPPA: 45mm Radiomir -tyylinen koppa harjatulla teräksellä -> PVD
KONEISTO: Käsinvedättävä
Avoimena:
RANNEKE: Ruskea nahkaremmi + mustalla tikkauksella?
Tuo musta PVD rikkoo TM #77641679. Vai oliko nyt tarkoitus valita harjattu teräs? Kovasti nuo mallikuvat ovat mustassa PVD kuoressa.
"The color(s) black is/are claimed as a feature of the mark. The mark consists of a configuration of a watch: the base of the watch case is cushion-shaped on top of which is a round frame portion encompassing the watch dial which is surrounded by a square portion thereabout, the square portion having bowed-out sides and rounded corners. Each of the corners slopes downward (i.e., away from the front of the watch), with the lowest point of the case being at the corner; the round bezel is beveled such that it slopes downward from the inside of the case to the outside and which surrounds the dial and is proximate to the edge of the case at the 3, 6, 9 and 12 o'clock positions, the dial features oversized stylized Arabic numerals 3, 6, 9 and 12 and markers at the remaining hour positions; large winding crown in the shape of a round-cut diamond, with the narrower portion of the sloping edge proximate to the dial and flaring wider, and featuring thick striations along the sloping edge; baton shaped hands. The dotted outline of a watchband is not part of the mark but is merely intended to indicate the position of the mark."
Lisäys: Saako tuota Radomir koppaa edes harjattuna teräksenä? Sivuilla ei ainakaan ole moista vaihtoehtoa 45mm koossa.
Ainakaan tässä ei ole mitään maininta PVD:stä tahi mustasta kopasta. Onhan se aika ihmeellistä, jos sitä luetaan pamin tavaramerkeihin.
http://www.inovia.com/products/directory/trademarks-number-77641679/trademark-owned-by-officine-panerai-a-g
Pahus tuli väärä TM numero, piti laittaman #77641696. #77641679 suojaa mallia, jossa on kruununsuoja. #77641696 suojaa Radomiriä ja on kaiken lisäksi päivitetty 31.12.2012 ja väri on poistettu tuosta, alkuperäisessä puhuttiin mustasta väristä. Tämä periaatteessa suojaa silloin tuon muodon väriin/pinnoitteeseen katsomatta.
http://www.inovia.com/products/directory/trademarks-number-77641696/trademark-owned-by-officine-panerai-a-g
Kunnioitamme luonnollisesti toisten immateriaalioikeutta. Kysymys on onko ko. muotoilu Panerain oma alkuperäinen idea vai onko se "varastettu" muilta? Jos se on "varastettu", niin ansaitseeko se meidän kunnioituksemme?
Jokainen voi tehdä omaa johtopäätöksensä.
Oheista linkistä löytyy kuvia 1930-luvun Omegan kelloista:
http://www.etsy.com/listing/123607096/antique-watch-omega-art-deco-men-circa
http://www.vintage-watches-collection.com/watch/omega-watch/omega-gold-cushion-redhill-dial-1935/
Aargh.. mikä vaihtoehto tuo "rajoitettu erä" edes on.
Rajoitettu Sarja, niin se pitäisi olla. Tokmannilla ja tarjoustalossa ne rajoitetut erät on...
Tuli mieleen että löytyisikö kuitenkin jokin muu ratkaisu? Eikö hommagekin ole lopulta tässä tapauksessa selvä jäljitelmä? Vaikeahan tuosta Panerai-design kuoresta on olla pitämättä... Se on hieno design mutta jäljitelmä. Onko muut vaihtoehdot todella selvitetty?
Viiden sentin ajatuksia mutta mitä muut ajattelevat? Arvoisa foorumi perustaja Bihn?
Kellohai
Kellohai sanoi:
Kellohai
Samaa mieltä. Olen ollut alusta sitä mieltä "halpa panerai kiinakopio", olkoonkin vaikka sitten homage, ei edusta sitä mitä itse haluaisin pitää ranteessa. Tähän pitäisi saada paljon enemmän mukaan Kellofoorumin omaa ajatusta ja suomalaista käsityötä. Ehdotin että ostetaan vaikka nippu Seikoja joiden taulut viedään vaikka kellokouluun modattavaksi- tuetaan samalla suomalaista käsityöosaamista ja saadaan varmasti ainutlaatuinen kello.
Luulenpa ne tahot ovat aika vähissä, joilta tällaisia kustomoituja sarjoja saisi edullisempaan hintaan.
Nykypäivänä niin moni asia on kopioitu ja muka-suunniteltu-uudelleen niin moneen kertaan että raja on hyvin häilyvä.
Mielestäni tämän hankkeen kohdalla mietitään jo liiaksi muistuttaako kello liiaksi jotain toista "rekisteröityä mallia". Tässä mielessä suuntalinjat oli jo Binh:n aloituksesta tulkittavissa, joten kelkasta voi aina jättäytyä jos käy omantunnon päälle.
Binh vetosikin tuohon Panerai vrt Omega -näkökulmaan, mikä on tässä yhteydessä ihan paikallaan.
Kellohai sanoi:
Kellohai
Auts kun oli kaukaa haettu. Suomalainen käsityö osaa maksaa yllättävän paljon ja toiseksi sitten väännettäisiin että "modautetaanko" Seikot näyttämään submarineria vai fifty five fathomsia, kun muuten menee liian eksoottiseksi valtalinjasta. Kyllähän kellon pitää olla sellainen, että sitä myös pystyy ja ilkeää pitää vaikka päivittäin kädessä, eli liian eksoottisetkin ratkaisut tai liika blingbling ovat asioita joita en liputtaisi.
EDIT: ajatusleikki homage-/kopioaiheen jatkoksi
Näyttää Panerailta, mutta onkin Getat
Näyttää Subilta, mutta onkin Seiko
Näyttää Volvolta, mutta onkin Ford
Näyttää 3GS:ltä, mutta onkin Lumia 620
Näyttää Omegalta, mutta onkin Panerai
jne
...(tätä listaa voisi jatkaa lähes loputtomiin, joten miksi torpedoisimme tämän hankeen tässä vaiheessa?)
^ +1
Aloitusviestistä pystyi jo näkemään suunnan, mitä ollaan hakemassa. Joten eihän tehdä tästä liian hankalaa?! Muuten tää leviää käsiin ja hinta on jotain muuta mihin ollaan sitouduttu.
stts sanoi:
+1
Seuraava äänestys sitten rannekkeesta.
5kpl vaikka vaihtoehtoja?
Oisko huono?
tJK
Pietulle kiitokset tuosta "salapoliisityöstä". :)
Täytyy myöntää, että Panerai on pitänyt huolta tuotteestaan! :)
Jatkakaa suunnittelua eteenpäin, mutta itse joudun kyllä luopumaan hankkeesta. (Ei huolta, en ole osallistunut äänestykseen! ;) )
Ehkä seuraavalla kerralla löydetään tyyli joka ei ole rekisteröity.
Omalla kohdalla ei niinkään haittaa se, että kello näyttää Radiomiriltä, vaan se, että tuo ulkonäkö on selkeästi rekisteröity Paneraille.
Eli nyt on sitten saatavilla nuo numerot 10 ja 11. Nopeimmat vieköön. :)
Noniin, jos en saa sitä nro. 7 niin otan sitten 11, sillä on minulle melkein yhtä suuri merkitys :) eli 43->11 kiitos :P
EJL sanoi:
Kymppi kelpaa allekirjoittaneelle.
Meillä taitaa olla edelleen tulliongelma jos kotelon muotokin on panerain omaisuutta...
Juu, aloitus oli kyll erittäin selkeä mihin suuntaan ollaan menossa, ja lisäystä vielä eli jos joka tapauksessa jotain TM:ää "rikotaan" tuon Radiomirin kanssakin niin samalla vaivalla ottaisin kyllä mieluummin Luminor kuoret. :)
stts sanoi:
Kellohai sanoi:
Kellohai
jne
Torpeedointia en ajatellut :) Keskustelua vain. Jäljitelmä vain todella tarkasti kopioi Panerain. Se on hieman eri asia tuo näyttää subilta, mutta onkin seiko... Ymmärrät varmaan.
Sekin on totta, että samaan hintaan on varmasti vaikea löytää muuta kuin kiinalaista tuotetta. Hinta ei ole paha.
Sen voin myös kokemuksesta sanoa, että jos lähtee tämänkaltaiseen projektiin niin se vie aikaa ja sisältää monenlaisia haasteita.
Tulipa mileen, että joku kellomerkkikin voisi lähteä tekemään erikoisedition. Ei se aivan mahdotonta ole. Sitä varmaan ei ole kysytty.
Maailmalla on toki paljonkin privat label-tuotantoa. Baselin kaukoitä-hallissa törmäsin tähän. En perehtynyt asiaan erikseen, joten en voi vinkata mihinkään suuntaan. Googlaamalla saa varmasti selville erilaisia vaihtoehtoja.
Eihän se haittaa vaikka tätäkin pohtii. Mutta älköön kukaan käsittäkö tätä väärällä tavalla kapuloiksi rattaisiin!
yst.terv. Kellohai
Kellohai sanoi:
stts sanoi:
Kellohai sanoi:
Kellohai
jne
yst.terv. Kellohai
Kellohailla on pointtia. Mitäs mieltä ihmiset ovat yhteistyöstä jonkun merkin kanssa? Esimerkiksi Orient, Seiko, Steinhart, Certina ovat edullisia ja tekevät kuitenkin laadukkaita kelloja.
paff sanoi:
Tähän kysymykseen haluan vastauksen - kuka vastaa rahallisessa mielessä, jos kellot jäävät tulliin esim. tavaramerkkisyistä? Vastauksen luulen arvaavani, mutta hyvä se on kertoa.
Ja toinen asia, sisältääkö 150 euron hinta verot ja tullit, vai tulevatko ne vielä tuon (toistaiseksi kuvitteellisen) hinnan päälle?
^Tämän tulliasian heitin jo ilmoille aimoaikaa sitten.
